I created this because I couldn't find a existing DIY. Hopefully someone will get some use out of this DIY. This DIY was performed on a 2005 Civic LX Sedan. :thumbup:
DIY: Convert your automatic shifter console to the manual shift boot console
Parts & Tools Needed:
- Phillips Screwdriver
- Flathead Screwdriver
- Part #: 77295-S5A-L11ZB
1. Before :ugh:
2. Pry off the trim ring, very easy to remove.
3. Next using your finger, there is a small whole in the center of the remaining trim piece at the top near the cup holder lid latch. Using that hole, pry off the trim piece.
4. On the front of the gear select lever is 2 phillips head screws, remove those, and remove the gear select lever by pulling upward.
5. Next, using your flathead screwdriver, remove the trim piece surrounding the gear select lever. There is 4 tabs, 2 on each side.
6. Remove the gear selection indicator, and set aside.
7. Remove the selector dust cover(?)
8. Remove the remaining black piece surrounding the selector level with the flathead screwdriver. There are 4 tabs, 2 on each end.
9. Remove the light bulb on the side of the black piece by rotating the bulb and tucking the wire out of the way inside the console area.
10. Pull the manual shift boot inside out, and cut and remove the ziptie holding the collar to the boot. There will be a hole in the boot where the ziptie went through.
11. Insert the gear selector level into the inside out boot and line up the whole from the collar that was removed with the top phillips head screw hole on the selector lever. Reinsert the 2 phillipshead screws, using the top screw to secure the boot to the lever.
12. Put the manual boot trim piece in place and secure using the retaining clips on the trim piece.
13. After :domo: Now sit back and enjoy
1. Before :ugh:
